I try to merge my set with a Korg Pa 800 set into Pa Manager but when I click on Import/Merge it's freezing and hanging.
FYI, the Pa 800 set is unzipped.
Korg Pa Manager freezes on importing Pa 800 set [RESOLVED]
Re: Korg Pa Manager freezes on importing Pa 800 set
A) Does it freeze when you click the Import/Merge button, or when it's trying to load a set?
B) Can you load the SET individually on it's own all fine?
C) Perhaps it's best to upload the set to be tested.
Answer: It freezes when it's trying to load a set.
Answer: Yes. I tried to load just one style (not User Sounds / UDK, only style) into my keyboard without any problem.
Answer: I sent you the SET (AB3.SET.rar) through WeTransfer.
Best Regards.
Best Regards.
As far as I can tell this set comes from a MAC system, because it has a lot of hidden duplicate Files that start with ._
Can you manually Delete all these duplicates from the Folders: i.e: ._FAVORITE01.STY
Ok, I deleted all hidden files (with extension ._) on entire set and sent it back to you.
No No Mis-understanding
I can delete them my self.
What i meant was delete those and then try to import/merge the set with the PA manager.
) I did but the same problem. That means the Korg Pa Manager still freezes on importing Pa 800 set.
Regard.
Yes, off course (common sense..What i meant was delete those and then try to import/merge the set with the PA manager.
Regard.
Ok, let's be more specific. Which MANAGER is this happening on?
STYLE Manager? Sound Manager?
Style Manager, which is my goal (combining styles).Which MANAGER is this happening on?
There is no problem on my side loading the Set?! Everything is fine.
Can you load the SET on it's own? Not using the import/merge button?
