Preload buffer
Share SETs & Discussion about KORG PA4X / PA700 /PA1000
LaurentiuTanasa
Preload buffer
Post by LaurentiuTanasa »
Hello! Can someone explain me what is the preload buffer and what it is used efficiently? or the sources from where I can read about that.
Thank you!
Re: Preload buffer
The preLoad buffer is used to load a portion of the sample in to Memory for fast access / playback and the rest of the sample is then streamed from disk.
mikiriki
Re: Preload buffer
Post by mikiriki »
Ciao! Per favore Admin, potresti spiegare più dettagliato dove esattamente viene caricato in Preload e dove il resto, cioè quale disco, in streaming?
Grazie
Re: Preload buffer
Salve. Sarebbe meglio se leggessi il Manuale dell'utente che spiega in modo più dettagliato.
