My sounds are gone?
saki
My sounds are gone?
Post by saki »
hy all ,i have big Problem.I have re-labeled my sounds and saved the set again. When I then load it into my Korg pa4x and access my sounds, my user sounds are gone and it always says GrandPiano. What is it?Thx all
Re: My sounds are gone?
Not sure what you've done, but sounds like your sounds/ samples haven't loaded, properly.
Try reloading.
saki
Post by saki »
I tried still not going. But when I load my unchanged set in, my sounds are inside. It always happens when I miss the sounds unbene then my user sounds
Does your new SET contain a SOUND Folder with the Sounds inside or is it empty?
Does your new SET contain a MULTISMP folder with a RAM.KMP file inside or is it empty?
saki
Post by saki »
There's everything in there and all folders are full Samples.The problem is that I can't do anything anymore. If I clean up something new then my samples are gone.Thx
Ok, if everything is there, the the keyboard isn't loading the SET fully maybe.
Instead of loading it as a .SET, go inside it and load the individual folders: STYLE / SOUND / PAD / KBDSET
saki
Post by saki »
Ok,I try to do it like this
