It's been a while haven't heard from you?
							Korg PA MANAGER V3 Upgrade
Re: Korg PA MANAGER V3 Upgrade
Thanks for reminding.
I was busy with gigs. I'll chat through the Team Viewer during this coming week.
It seems that the Korg PA MANAGER V3 Upgrade has serious bugs according to some reports in Korg forum.
That's why I did not contact you by chat until the bugs are fixed.
Here is the link to discussion about Pa Manager V3 in Korg forum:
http://www.korgforums.com/forum/phpbb2/ ... 0&start=60
Thank you
Thank you
Sorry for late reply cause busy with jobs.
I would like to know if Korg PA MANAGER V3 can do two things that I need:
1- Create Sounds from Samples (AIFF) for using in Pa4X like other sounds.
2- Clean up samples, for example Delete/Get rid of greyed samples with (*) in RAM to save more spaces.
Waiting for your answer and if these are possible, next week I'll contact you through TeamViewer for installation of V3 in my iMac.
Hello I need help I make the organ sounds using your software and I managed to get only 11 zone and I want more Why does the software not allow to insert more only until 11?
Waiting for an answer with gratitude Oren
Hi,BRK wrote:Hi,
It can create Sound from scratch, using .wav/ksf/kmp. Currently there is no AIFF support.
Yes, with the SAMPLE Manager, it can clean up any unreferenced samples that may exist.
Hi,oren kami wrote:Hello I need help I make the organ sounds using your software and I managed to get only 11 zone and I want more Why does the software not allow to insert more only until 11?
You can get up to 128 Zones. You're probably not spreading your zones. Use the From / To values to change the start / end of the zones.
Which is more stable, the windows or mac version?
							Bingo is so much fun with these awesome sun bingo bonus codes so check them out.
The software is originally built for Windows. Mac version is simply an emulation, which is exactly the same thing, in 'theory'.EmeryDav wrote:Which is more stable, the windows or mac version?
i have problems with opening app korgpamenager mac
