hi every body
how do i import a sample and arrange notes on key of keyboard  and save as new sound user??
						how do i import a sample and save as new sound user??
Re: how do i import a sample and save as new sound user??
Have a look at the SAMPLE Manager Video Tutorial: http://www.korgpamanager.com/tutorial/
hi admin
i saw the SAMPLE Manager Video Tutorial. but how save as new sound user , imported new sample???
thanks
thanks
It's the same as you would on the keyboard.
Step 1: Import WAVs to create a MultiSample.
Step 2: With the SOUND Manager, you need to select/assign that MultiSample to a Sound OSC.
Select any sound you want to assign the MultiSample to. On the OSC Basic Menu, if it says ROM [Factory] click and drag up/down to change it to RAM [MultiSample], then click and drag the number to select your MultiSample you wish to assign.
tank you dear admin
is possible import.export of sample converted from pa80???
You just deleted the post?
Perhaps send me the SET so I could Investigate?
hiAdmin wrote:You just deleted the post?
i sent myset and mysample via private message
tanks
hi
i done reinstall software then fixed my problem
tanks
tanks
You probably were not using the latest version. Please make sure you always Update and use the latest version.
