This folder does not contain any Korg Pa Set files
Rnonik
Post by Rnonik »
I downloaded some sets from the internet, and I want to load some sounds from the set into Korg Pa Manager so that I can add them to my pa900 organ. But I get the message in all of them: This folder does not contain any Korg Pa Set files.
What can I do to successfully load a sound into Korg Pa Manager?
Re: This folder does not contain any Korg Pa Set files
You need to make sure that you're loading a .SET rather than a normal Folder.
Make sure the folder name ends with .SET and that it has the relevant Folders inside it.
Rnonik
Post by Rnonik »
But how do you know if it's really a set or just a folder?
The name of the Folder should end with .SET
Rnonik
Post by Rnonik »
All the folders end in .SET but they are still not recognized as a set
What is inside the .SET folders?
Does it contain the STYLE / KBDSET / PAD / SOUND / MULTISMP / PCM Folders too, with files inside?
If yes, then the issue may be Unicode related. If your Paths contain some unicode names.
What language is your OS? Hebrew? Arabic? Greek ?
Try copying the SET to your DESKTOP and load it from there.
Rnonik
Post by Rnonik »
This contains: GLOBAL, MULTISMP, PAD, PCM, PERFORM, SONGBOOK, SOUND, STYLE
Does your Path to the folder contain some unicode names ?
Rnonik
Post by Rnonik »
Thanks a lot for the advice, I'll try it today.
Rnonik
Post by Rnonik »
Thank you very much for the help. I tried what you recommended and it helped. I realized that all the folders in the path to the set file must have English names.
