Check Empty Track Sounds remaps incorrectly [RESOLVED]
emreuyar
Post by emreuyar »
Hello
In the SET Manager Style section, after the Check Empty Track Sounds process, there is a problem with the chord tables.
In my case;
Var 1 CV1 Chord Track 5 is in use and connected to the user sound
Var 1 CV2 Chord Track 5 is empty, regardless of whether CV1 is in use or not, CV1 is directed to the factory sound.
Currently, many styles play piano instead of their own sound.
My PA Manager Version: v5.1 Build 2801
Re: Check Empty Track Sounds remaps incorrectly
Checking the 'Check Empty Track sounds' process has no relation with Style CV's, in the sense that it doesn't alter them. It only creates a REPORT to show you if there are any USER SOUNDs are being pointed to an EMPTY Sound Position.
A SOUND can only be assigned to a single TRACK Once. You cannot have multiple sounds on different CV's. You may be confusing something.
emreuyar
Post by emreuyar »
I didn't tell you that there are different sounds. There is an event content in cv1 track 5 but the event content in cv2 track 5 is empty. I also know that there is no sound change. Since cv2 track 5 is empty, it remaps to the factory sound even though there is an event in cv1 track 5. I encountered it while making a pa3x set. You can try it and see.
It is not a call for help to solve my problem. It is a bug detection.
Thank you for clarifying.
We have now found and fixed the issue.
This would be resolved with the next update.
