Korg os v3 next, and PA manager
alex.alexutz89
Post by alex.alexutz89 »
I'm a new user here and considering purchasing PA Manager full version asap. I wanted to ask if the PA Manager will be updated soon to support the new korg pa4 os version 3? At the moment I think PA Manager only has os 1.2 and os 2+ options when loading a new set in the manager.
Or will there be any issues if I save a .SET with os v2+ and then load it in my pa4x with os v3 on it?
Re: Korg os v3 next, and PA manager
Please check our FAQ section (https://www.korgpamanager.com/faq), which has a detailed answer as to what is happening with the Next OS.
Redwood
Post by Redwood »
i can load sets made with Korg PA Manager into my PA4X V.3 Next
When i try to load another Set made with PA Manager directly into PA4X to merge 2 sets it comes to error: Not enough Memory for PCM Samples
It could be the bug of new OS V3.0 Next or PA4X cann't work with PCM Memory allocations made by PA Manager Software.
However i can load in PA Manager Sets made on PA4X with more than 400MB RAM and add Styles and User SOunds from different Sets, but i don't know wheter it will be playing correctly.
As mentioned in the previous post, the PA Manager currently does NOT support OS V3 Next.
You cannot load OS V3 sets in to the PA Manager. Nor can you load a SET which is greater than 400MB.
---------------EDIT---------------APRIL 2019
OS Next support has now been added with v3.3+
