Importing Stereo Wave Files ! [RESOLVED] v2.2+
Bili2015
Post by Bili2015 »
After importing Stereo Wave Files and Save and Update KPM Files to Set again, everything Works Fine !
But the Problem is when reading Set again with updated Wave Files, error is coming up with following argument: Reading error ! and the Program dont work with this Set again !
Please make an Update without Reading errors with importing Stereo Files !
with Mono Files everything is working Fine and there are no Problems !
Re: Importing Stereo Wave Files !
We haven't encountered any problems with this. Make sure you are using the latest version?
Can you provide more info please:
Which keyboard model is the SET made with ? PA2X / 3X / Other?
Perhaps zip and attach the stereo Wav for testing?
Bili2015
Post by Bili2015 »
I'm allready use the lastest 2.1 Software !
I'm on PA3X !
The wave files are Stereo Drum Sounds.
any Ideas ?
Just to confirm, the latest is, VERSION 2.1.2315
We don't have any issues on our side and no one else has complained of such a problem.
Can you please zip and send via wetransfer.com an example of the WAV file and SET you are using, for us to test?
Bili2015
Post by Bili2015 »
Hello again,
i updated the latest Version now, but same problem is happen.
you should bring an update where reading again makes no problems !!
I work with over 1300 Samples every single stereo sample makes Problem !
I think my Samples are not the problem your software need to be updated !
Once again. We don't have any issues on our side. It may be system specific.
If you want the problem solved, then can you please zip and send via wetransfer.com an example of the WAV file and SET you are using, for us to test?
