Would it be possible to add an option that allows mapping or converting drum notes between different Drum Kits?
For example, when I load a Style that uses one Drum Kit and then try another one, some drum hits don’t match because the key assignments are different.
It would be great if PA Manager could detect the note layout of both kits and let us remap the hits — for example: move Snare from D2 to C#2, Kick from C1 to B0 — so the rhythm plays correctly without editing each event manually.
That would save a lot of time and make experimenting with different kits much easier.
