v5 three errors from me [RESOLVED]
Posted: 03 Aug 2023, 17:48
I have Korg PA Manager for one day and I've encountered some errors:
1. This is the most weird, because no error message is raised. The exe process is been killed. After I want to load a KST. But the KST has nothing, because second time I load it correctly. So, maybe something with memory management, I don't know. My PC have 16GB of memory, but I've realised that Korg PA Manager is 32 bit (
2. When you want to import a style from another KST, even if the options of copying user voices are ticked, not all voices are copyied to the new pack. And the new voices which were copied are not remaped in styles. When I load the KST in keyboard I must set myself the new sounds from the new locations.
EDIT:
3. The UI does not recognize diacritics in translated ini files.
BTW: Make it 64bit, we are in 2023, the most used OS now is 64bit. Memory allocation will be definitelly increased by switching to 64bit.
And I will wait for the update when PA5X styles could be edited in this program.
EDIT:
