In latest version when copy style in another kst
Pads not copied Even if the ticks are on
Please fix it's very important
Kst mod pads not copied
Re: Kst mod pads not copied
You're confusing with the OLD workflow.
The PA5X no longer works as the previous models.
The PADs are now embedded inside a Style. So when you copy a style, the Pads are also copied inside the style (if enabled in the copy options)
But you will NOT see a PAD in the pad section any longer.
