KPM crashes when loading multisamples [RESOLVED]
I've already spoke on chat system, but just for tracking, I put the issue here, too.
KPM will not load big KST files.
Currently, I cannot use the application, as long as my KST is very big and it is not loaded by the program.
I hope this error will be fixed very quickly!
Regards,
Re: KPM crashes when loading multisamples
Issue has now been resolved with a new update!
I've made the update, but the issue is still there.
Check the "Copy from another KST" function... it crashes...
When I load the KST in the main window (as the main KST) is ok, it loads it correctly. But if I load another KST as main and I want to load my big KST in the right part of the software, it crashes.
Oh it seems we fixed the LEFT side only and not the Right side when copying from another SET.
...update coming
Ok... Seems the second "1030" version solved the right part, too.
PS: Why are you updating with the same version number and not incrementing it?😁
