Korg Pa manager export nod corekt kmp
saki
Post by saki »
Hy, If I export my UserSounds as kmp and then in nki format there is always a noise in the sound.But if I export the same thing via the Pa4x as kmp and then as nki the sound is Ok.Why can't this be done via the Pa manager correctly? Thx
Re: Korg Pa manager export nod corekt kmp
Just tested a few exported MS from the PA Manager with various other software's that support .KMP and there is no problem loading them.
How are you converting them to NKI?
Or can you share a .KMP to test here that isn't working ok?
saki
Post by saki »
I convert the Kmp with Awave in sf2 then with the Extreme Sample Converter in nki format. And when I import that into kontakt 6, there is always a noise after the sound.
That has nothing to do with KORG PA Manager.
You're exporting it out from AWAVE another format (sf2) and then sample converter(nki). That's 2 conversions!
When it enters AWAVE the .KMP is fine! What happens afterwards is not an issue from us.
saki
Post by saki »
But I first exported with the Korg pa to kmp and then continued with Awave and the Extreme Sampler in the Nki format
The .KMP format exported from the PA Manager is perfectly fine.
Check in AWAVE, you will see that all samples load & play well.
When you begin converting to another format i/e to sf2, that is the responsibility of AWAVE.
Something seems to break when it converts from kmp to sf2 or from sf2 to nki.
That is no longer the responsibility of PA Manager.
saki
Post by saki »
Okay Thx
