Matching problem in new set
erez83
Post by erez83 »
hii
i created a new performence set
in the model I chose pa1000
I copied a few performence from 2 old set
and i saved it
now when im trying to load it on my pa1000
it doesnt load at one time
and there is a message:
set folder not generated by this intrumant....
what can b the problem
Re: Matching problem in new set
Problem the fact that you selected PA1000 from the list, but the Performances that you are taking are actually from a lower model.
Check under their names it writes the model.
So when you save the SET, it saves it in the old 3X format with a PERFORMANCE folder instead of a KEYBOARDSET folder.
So either rename your PERFORMANCE folder inside your SET to KEYBOARDSET
or
when you copy the performances make sure there at least one PA1000 version transferred over.
(in the future, please post any problems in the Bugs & Errors section of the Forum.)
erez83
Post by erez83 »
thank you very much
for the fast answer
next time ill post in bugs section
