KORG PA Manager v2.2 [RELEASED]
News & Updates for KORG PA Manager.
Postby Admin » 27 Jan 2016, 12:00
#Version 2.2.2527 (Build: 27 January 2016)
+STYLE Manager - KORG PA4X Support Added
+PERFORMANCE Manager - KORG PA4X Support Added
+PAD Manager - KORG PA4X Support Added
+PCM Manager - KORG PA4X Support Added
+FILE Viewer - KORG PA4X Support Added
+WAV Import - Now Supports Loop Points
+WAV Export - Now Includes Cue chunk / Loop Start/End Points
+Main Screen - Recent Paths button added
*Stereo WAV Import Fix
*SAMPLE Manager - MultiSample Import Looped Sample Fix
*Loading PA900 Samples - Missing Header Fix
*STYLE Manager - Merge Bank Name Fix
*STYLE Manager - New SET - Didn't fully Flush Sound & Pad Names Fixed
*PAD Manager - Location Label version Fix
*PAD Manager - HTML Report / Empty Bank Fix
*PA600 Mode - User 3 & User 4 Tabs were still showing
*Fixed not loading of some Samples when Importing PA800 UserDK
*Improved PA80 Sample Support
*You can now select any model version after using the 'Create New Set' option
*STYLE Properties - Possible crash prevention when saving fixed
*Internal Stability improvements
http://www.korgpamanager.com
tahir1983
Re: KORG PA Manager v2.2 [RELEASED]
Postby tahir1983 » 28 Jan 2016, 08:46
Wonderfull...! So now awaiting for full pa4x supporting and issue of compressed sample(multisample) operating!!!
congan2
Postby congan2 » 03 Mar 2016, 16:50
How can I update for my KORG Manager? I used mine yesterday but did not see any automatic updates like before?
Postby Admin » 03 Mar 2016, 23:20
congan2 wrote:How can I update for my KORG Manager? I used mine yesterday but did not see any automatic updates like before?
You can always download and install the latest version from our website: http://www.korgpamanager.com/download
congan2
Postby congan2 » 06 Mar 2016, 00:54
When I download the updated, Do I need to request the Activation Code again?
Postby Admin » 06 Mar 2016, 13:07
congan2 wrote:When I download the updated, Do I need to request the Activation Code again?
No, you simply update and continue using as normal.
Return to “News & Updates”
