I noticed issues like this with some Styles:
I don't think all styles act like this. For some Styles, this order of STS is not accurate.
STS order error [RESOLVED]
Re: STS order error
So, the Sounds are correct, but the STS Order is wrong?
A) Is this straight by default or after you've fiddled with the style? [did you copy/paste any sts]
B) Is this only with PA1X Styles?
Re: STS order error
No I haven't changed the Style or SET using the software just yet.
These particular styles are "official Korg" styles that were added not too long ago. I think they were part of a new OS update for Korg PA3x or something, but can't remember for sure.
The header (STS name) is correct, but the content is not. So when you Select STS 1, you're looking at the keyboard tracks for STS 2 and vice Versa...I think this is happening at ramdom, because some Styles were ok. I'll check some more styles later...
Re: STS order error
Ok can you attach or mail me one Fav Bank and tell me on which Style/STS this is happening please ?
İll take a look. Thanks.
Re: STS order error
Ok, here it is:
Look at the Favorite 1 bank (Page 1) ..Moonlight Ballad and British Pop styles
Check out the STS 1 and STS 2 for both styles.
- FAVORITE01.rar
- (340.6 KiB) Downloaded 1357 times
Re: STS order Display Error
Ahaaa, interesting never came across this during testing
Will fix in the next update. Thanks
Great. Again, I'm not sure if that happens only for these 2 styles, or it's a random problem with USER contents as well. Also I haven't tested how it works the other way around meaning, what would happen if you save a SET like that with the software and import it back into the keyboard. Will the keyboard read the STS settings in the right order or just like it was in the software?....etc. So you might want to take a look into those possibilities when you got a chance.Admin wrote:Ahaaa, interesting never came across this during testing
