pcm damaged [RESOLVED]
hanidamiri
Postby hanidamiri » 17 May 2017, 19:11
hi,
can u help me please?
when i use the pamanager my pcm is damaged
why?
hanidamiri
Re: pcm damaged
Postby hanidamiri » 17 May 2017, 21:49
also i have this message
you are runningkorg pa manager as an administartor
please close korg pa manager and run it withnormal user privileges
what should i do????????????????????????????????????
Re: pcm damaged
Postby Admin » 18 May 2017, 00:55
Let's clarify a few things.. When you open ANY set with the Sample Manager and click on a Sample. Do all sample sound damaged? Like hisssss noise?
You seem to be running the pa manager with Admin privileges.
Try:
1. Right-click the application’s shortcut, and then click Properties.
2. In the Properties dialog box, click the Compatibility tab.
3. Un-select the 'Run This Program As An Administrator' check box, and then click OK.
hanidamiri
Re: pcm damaged
Postby hanidamiri » 18 May 2017, 07:25
hi,
yes its true when i load any set on the sample manager and click on any sample, its damaged ,all samples are damaged,why?
i tried alot of sets its same
also on my pc its not selected to run as an administrator
i dont know why is this dialog is appearing?
hanidamiri
Re: pcm damaged
Postby hanidamiri » 18 May 2017, 10:47
hi
thanks for help
every thing is ok now
Kokoaus
Re: pcm damaged
Postby Kokoaus » 04 Jun 2017, 10:31
I got same problem with. i follow the steps you write it but still the damaged and noisy samples sounds any other solution...
Re: pcm damaged
Postby Admin » 05 Jun 2017, 22:39
Try the following to fix the issue:
Click on: Start>>Control Panel>>Region>>>Administrative>>Change System Locale: Try English UK and restart the PC.
Return to “Bugs & Errors”
Who is online
Users browsing this forum: No registered users and 1 guest
