Page 1 of 2
Error importing wav [RESOLVED] v2.2+
Posted: 29 Nov 2015, 22:45
by gewa
From sample manager when importing wav file error dialog comes up.
See attached
Re: Error importing wav
Posted: 02 Dec 2015, 02:54
Can you attach the .WAV file you are trying to load?
Posted: 02 Dec 2015, 04:18
by gewa
I have attached zip in my original post. Btw: I can load the same file into PA3x no problems.
Posted: 02 Dec 2015, 20:47
Having examined the file, I can say this error will fixed with the next update.
Posted: 07 Dec 2015, 12:50
by Bili2015
Hi there,
the same issue happened to me yet please bring an update !
Posted: 07 Dec 2015, 16:13
by gewa
I did few more tests, with different wave files, and no matter what the error is the same. Even when you export multisample from the manager and try to import back the same wave file the errors happens.
Posted: 07 Dec 2015, 22:59
Try this: Click on Start>Control Panel>Region and Language>Administrative>Change system Local>>English United Kingdom
Restart your PC and see if that helps ?
Posted: 09 Dec 2015, 00:38
by gewa
Admin wrote:Try this: Click on Start>Control Panel>Region and Language>Administrative>Change system Local>>English United Kingdom
Are you serious? I dont want to change my default locale, so I can import wave file. You are being very unprofessional, instead of providing a proper patch for it, you suggesting system modification.
Posted: 09 Dec 2015, 21:56
It's a temporary fix to see if it fixes the problem. If it does, then we'll know what the problem is.
Ofcourse there will be a patch, but the problem needs to be identified first.
Posted: 14 Dec 2015, 00:19
by gewa
I have tried that and does not help at all.
