Cherrypicking a smaller SET from PA800, PA900 SETs for PA300
Posted: 28 Mar 2016, 02:22
by Sam
Ok, here's the question I got from a fellow Korg users. Apparently, the PA300 is now capable of importing user samples though the SET can't be larger than 32mg. So he was wondering if he could use the PA Manager to Cherry pick a smaller SET from bigger SETs that belong to other models such as PA600, 800, 900 ....(With this in mind that certain keyboards might have specific O.S. features as part of the Style structure that might not be supported with the PA300.)
Re: Cherrypicking a smaller SET from PA800, PA900 SETs for PA300
Posted: 28 Mar 2016, 10:34
Hi Sam,
The pa300,600/900/3x/3x Le are all part of the same family, which means they're all compatible with each other.
So the answer is yes, the PA Manager can be used to make a smaller SET from bigger SETs, as long as the 32MB threshold isn't exceeded.
Posted: 28 Mar 2016, 16:03
by Sam
And the same goes for SETs from older keyboards then. He should be able to use the content from PA800 or older as well, right?
Posted: 28 Mar 2016, 23:25
Yes, correct.
