how do i import a sample and save as new sound user??
zamanphp
Post by zamanphp »
hi every body
how do i import a sample and arrange notes on key of keyboard and save as new sound user??
Re: how do i import a sample and save as new sound user??
Have a look at the SAMPLE Manager Video Tutorial: http://www.korgpamanager.com/tutorial/
Best Regards
zamanphp
Post by zamanphp »
hi admin
i saw the SAMPLE Manager Video Tutorial. but how save as new sound user , imported new sample???
thanks
It's the same as you would on the keyboard.
Step 1: Import WAVs to create a MultiSample.
Step 2: With the SOUND Manager, you need to select/assign that MultiSample to a Sound OSC.
Select any sound you want to assign the MultiSample to. On the OSC Basic Menu, if it says ROM [Factory] click and drag up/down to change it to RAM [MultiSample], then click and drag the number to select your MultiSample you wish to assign.
Best Regards
zamanphp
Post by zamanphp »
tank you dear admin
is possible import.export of sample converted from pa80???
Yes.
You just deleted the post?
Perhaps send me the SET so I could Investigate?
zamanphp
Post by zamanphp »
Admin wrote:You just deleted the post?
hi
i sent myset and mysample via private message
tanks
zamanphp
Post by zamanphp »
hi
i done reinstall software then fixed my problem
tanks
You probably were not using the latest version. Please make sure you always Update and use the latest version.
