Convert user sounds and user drum kits from PA3X to PA2X
Posted: 04 Feb 2015, 01:36
by cristimusic2006
Hello there,i would like to know if i can convert sounds and drum kits saved in user sound and user drum kit,created in PA3X which have samples or not.
I have PA2X and i want to load some drum kits with samples and some user sounds with samples from PA3X. Can i convert and load in Pa2x?
Re: Convert user sounds and user drum kits from PA3X to PA2X
Posted: 04 Feb 2015, 14:30
Currently with v1, this is not possible. Hopefully v2 will be able to do this. So check back soon when version 2 arrives. :)
Posted: 04 Feb 2015, 14:44
by cristimusic2006
Thank you for reply and i will wait V2. If that will not be possible in v2, i will write in the request topic :)
Posted: 25 Mar 2015, 00:28
krissna wrote:I tried to merge some sound from pa3x to pa2x set, completed and saved
While I opened the merged pa2x set, it detected as Pa3x set
Do you have the same problem ?
When you reopen the new SET with the PA Manager does it detect as PA3X ?
Can you zip and attach / mail me the SOUND Folder Folder to take a look please?
Posted: 11 Feb 2016, 11:04
by hakibit
Same Problem .
Posted: 11 Feb 2016, 14:10
hakibit wrote:Same Problem .
This topic is a year old and in regards to version 1! We are now in version 2.2 and this issue long been fixed.
What is the problem exactly?
Posted: 11 Feb 2016, 15:03
by hakibit
Pa2 Setime Pa3 den DK cekiyorum.Buraya kadar hersey tamam.
Seti yedekliyorum.
Ancak bu seti birdaha acinca bu bir Pa3 setidir diyor... ?
Posted: 11 Feb 2016, 22:09
hakibit wrote:Pa2 Setime Pa3 den DK cekiyorum.Buraya kadar hersey tamam.
Seti yedekliyorum.
SETI www.wetransfer.com'a yukleyip, bana yollayabilirmisin ? Ve hangi DK bunu yaptigini iza edebilirmisin?
Posted: 12 Feb 2016, 12:59
by hakibit
Setimin boyutu 256 mb yi geciyormus.
Tahminen onun icin Pa3 Seti olarak algiyormus KPM
