KORG PA Manager v1.1 [released]
News & Updates for KORG PA Manager.
Postby Admin » 01 Jul 2014, 15:28
KORG PA Manager v1.1 [RELEASED]
CHANGES:
+Support for Korg microArranger
+Sound Manager Updated [reads sound properties]
+Sound Manager reads Multisample List
+Sound Manager HTML Report now adds OCS properties too
+Auto Update Feature Added
+Auto Language Detect
+French Language Added
+German Language Added
+Russian Language Added
+Serbian Language Added
+Added Page Numbers to Reports
+Global Shortcuts Added [ctrl+C / ctrl+V / Del / F2]
+STYLE Manager - Access Style Properties in MERGE Mode
*Fixed Hang in Task Manager problem when Exiting
*Fixed problem with 'Unable to Load SET' error
*Fixed Possible Crash when starting Sound Select
*Fixed incorrect STS Order Reading
*Fixed incorrect display of PADs [Style Merge Mode]
*Auto Admin switch if necessary
*PA3X Sound List Fix
*Style Manager - Fixed Pad Send C channel display
*Style Track Info - renamed to Style Properties
*Style Properties - Hi/Low Limits Fixed
*Style Properties - Reset button causing flicker fix
*Style Properties - Report now includes SET Name
*Style Properties - Hi/Low drop down list extended
*Fixed correct Saving by checking for illegal characters
*Internal improvements
For more information, visit: http://www.korgpamanager.com
tahir1983
Re: KORG PA Manager v1.1 [released]
Postby tahir1983 » 01 Jul 2014, 18:43
Awesome kardeshim...! thank you very much..... that is agreat improvment to get info from user sounds... so now it remains to wait for results concerning user drum kits viewer .... ! Good luck to you!
Sam
Postby Sam » 09 Jul 2014, 15:54
There will be a download link sent to registered users?
Postby Admin » 09 Jul 2014, 17:41
tahir1983 wrote:Awesome kardeshim...! thank you very much..... that is agreat improvment to get info from user sounds... so now it remains to wait for results concerning user drum kits viewer .... ! Good luck to you!
Thanks Tahir...
Sam wrote:There will be a download link sent to registered users?
The program should automatically inform you that an Update is available... [if you have an internet connection]
otherwise, simply re download it from the website.
Return to “News & Updates”
