Sound problem when Merging between 2 sets [RESOLVED] Topic is solved
erez83
Post by erez83 » 30 Apr 2019, 16:21
Hey
I really like your software
Yesterday I worked with her for the first time
And everything is very convenient and easy
now
I opened a new set
And copied styles from 2 other sets
And some of the sounds from the second set's
were saved On the place of the first set sounds
How can we avoid such a problem?
I know the software does it itself
And she did it in most styles
But in some styles she just did not do it and had a problem
Re: Sound problem when Merging between 2 sets
Post by Admin » 30 Apr 2019, 22:00
"...And some of the sounds from the second set's were saved On the place of the first set sounds"
That is simply not possible.
Unless, the Style you copied did not have sounds assigned to those positions, which kept them empty in the first place.
or
What was empty on one set, is now occupied because you've copied many styles/sounds, so the slot that was "empty" on the original set, is now filled in with some other sound.
erez83
Post by erez83 » 02 May 2019, 16:14
thank you very much
this is it!
